-   -   Heat not blowing to 2nd fl bedrooms (http://www.diychatroom.com/f17/heat-not-blowing-2nd-fl-bedrooms-165604/)
newwifeey1 12-04-2012 07:01 PM
I live in a two-story single family and I've got a brand new furance and also ducts recently cleaned. I just cant figure out why sufficant heat is not blowing through the 2nd story floor vents. PLEASE HELP
bbo 12-04-2012 07:03 PM
maybe one of the dampers got flipped?
JJboy 12-04-2012 08:31 PM
Check the temp in all registers in cooling and heating. The temp difference should be small
concretemasonry 12-04-2012 08:52 PM
Also, make sure you have adequate return air vents. If the old air is not drawn out, the new air will not get there is any qualtity.
Dick
Missouri Bound 12-04-2012 09:26 PM
Is it safe to assume that the old system worked properly? Is the new unit smaller than the old? Any other changes? I too would look for a closed damper. Have you gotten any help from the installer yet?
techpappy 12-04-2012 10:43 PM
try running the circulating fan on constant low or medium speed..you may have to call the installer back to set up the thermostat/controls to do this..
