Heat n glo fireplace issue
I have never heard of that where I am and we are cold or colder than you. There are minimum clearances to that unit and hopefully your blown insulation has not decreased them and caused a fire hazard. If you have the model with the circulator fan then try run it to get rid of the effect. Most of those units can have that fan as an add on but need 120 volts to it. It can be ordered/added on later. Some have variable speed controls so you can slow it down. Try run the unit longer in cold weather otherwise you are going to get condensation in it and it will rust out and that can cause CO problems. You can adjust the flame size with the gas valve on some models and keep it low.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
