Old 05-18-2008, 11:07 PM   #1
Heat kicks on without thermostat
I am currently renting a room with its own thermostat. It functions, as the blue spark flies to let me know..
The heat kicks on "by itself" and pursuing an answer.
The irony of it kicking on *after* closing down the window for the evening, all while the room is still roasting from the day is even more perturbing.
Should I assume prankster with a bit of rooming house know how? I know the landlord would not want this heat kicking on for a 75 degree room .....
I did note a lamp flickers, and even a wall SNAPS when it kicks on. Like something much bigger than a thermostat is going on here...Also, the thermostat for the room is indeed off, no connection. Should I just packup and run before the big fire?
meanwhile, window is open this late evening, I am on fire to the full blast heat unstoppable.
bgd73 is offline   Reply With Quote
Old 05-23-2008, 09:17 PM   #2
oops, did I do that!
Will the occupant of apartment 2B please report to the main office....and bring proof of fire insurance.
8 Ball is offline   Reply With Quote
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 11:02 AM
radiant floor heat thermostat kornbln Electrical 5 03-27-2008 01:45 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
recommend Heat only programmable thermostat? pesphoto HVAC 11 12-26-2007 07:26 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 01:04 AM
