Old 10-15-2012, 12:32 PM   #1
Heat keeps running
even after the temp inside the house has been reached and passed.
This is a goodman heatpump/furnace.
put the temp at 68 at Tstat, gas heat comes on room temp passes 68 but the unit never shuts off.
What would be cause(s) of this issue? thank you all...
cyp555 is offline   Reply With Quote
Old 10-15-2012, 01:08 PM   #2
JJboy's Avatar
Heat keeps running
Check if your heat pump turn off after the furnace turn on. Check if thermostat is set to heat or Em heat.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-15-2012, 03:07 PM   #3
Heat keeps running
hi,
checked the thermostat. it is on Heat.
I do not follow your advice on checking the heat pump on/off.
the heat pump continues to run even after the set temp on tstat has been reached. it is like a switch is not engaging to tell the unit to stop, just do not know what it would be. any other idea(s)?thanks
Old 10-15-2012, 04:01 PM   #4
JJboy's Avatar
Heat keeps running
Set your thermostat to Em Heat. At this point only furnace should work.
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Long running furnace hurt heat exchanger? quincy HVAC 6 11-09-2010 07:01 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
HVAC system heat won't run with standby generator running... PTighe Electrical 70 09-14-2009 06:35 PM
