Old 05-07-2010, 10:19 PM   #1
Heat issue in the office
Hi folks,
I recently purchased a home that's a 1.5 story. The only room upstairs is an office. Being May, i have begin to notice that my 2 computers in the day/evening really heat up the office to the point where it's a bit uncomfortable.
about the office upstairs:
1. the whole house has a single AC unit.
2. office specifically has 1 return and 2 vents for heat/ac
3. has ceiling fan
4. room is roughly 14 x 20
5. Thermastat is downstairs and not designed to switch
An idea that i had, was to get maybe 1 or 2 bathroom fans (if i can find some silent ones) and put them on the ceiling in the office. Turn the fan on, cause a vacuum situation in the office and hopefully pull the colder air from downstairs.
I'm looking for any solution but low cost / maintenance would be my preference. I'm looking for a good way to get that nice cool air downstairs to this office.
Thoughts?
Jon
repoman is offline   Reply With Quote
Old 05-08-2010, 12:12 PM   #2
An old Tradesmen
Go to thermostat. Turn fan switch to on.
See if that helps any.
Doubt it will keep the room cool when you get to the hot months. But might be bearable.
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
