Heat Exchanger?? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-21-2008, 08:27 PM   #1
Unhappy
Heat Exchanger??
Can anyone help me in regards to replacing or repairing a heat exchanger. Can these be repaired or replaced? Is it cost effective to replace the exchanger or would we be further aheadd replacing the full furnance. It is a gas Heil dc90 approximatley 12 years old. Any suggestions or information, would sure be appreciated. Thanks!
Richard
sunsetacres1318 is offline   Reply With Quote
Old 11-21-2008, 09:15 PM   #2
Richard
cant be repaired ,usually under warranty for 20 yrs
must be licensed to have supplier exchange the heat exchanger for you
labor runs from 650 to 1000 dollars
kennzz05 is offline   Reply With Quote
Old 11-21-2008, 10:46 PM   #3
An old Tradesmen
Rewards Points: 6,928
I would have a contractor find the cause of the failure.
Then, I would op for the heat exchanger credit, and get a new furnace.
Yes, it must be another Heil.
Old 02-25-2009, 05:19 PM   #4
Mechanically Inclined
I've noticed in a few threads people were quoted $600-1000 labor to replace a heat exchanger, and one hvac tech siad it takes about 3 hours. So it costs $300 an hour to do this? Trying to get a grasp on this.
diggerdave is offline   Reply With Quote
Old 02-25-2009, 05:55 PM   #5
Most companies prefer to just replace the furnace so the price is high to dissuade heat exchanger change. That's not to say that this is motivated by greed, rather, when a furnace is over ten years it's usually better to just replace it since the current models available are a better choice.
hvaclover is offline   Reply With Quote
Old 02-25-2009, 05:57 PM   #6
That furnace was just a POS Been. I had too many go belly up on me to be able to say it was install related.
Old 02-26-2009, 10:15 AM   #7
HVAC / Plumbing
Agreed. Are they still made by inner city ( something like that))products ?? I have seen several with cracked heat exchangers
kenmac is offline   Reply With Quote
carrier/payne furnace heat exchanger issues gomongo1 HVAC 9 11-29-2014 08:29 PM
Cracked heat Exchanger darman16 HVAC 4 10-27-2008 09:11 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 03:57 PM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 06:59 PM
