Heat Does Not Come On Unless I Reset Thermostat. What The Heck - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 10:44 AM   #1
Heat does not come on unless I reset thermostat. What the heck
I've been trying to figure this out:
Furnace will not come on (intermittently, but typically not) for the morning cycle. If I go to the thermostat and turn the system OFF and wait for the "click" then to "Heat" and wait for the click, the furnace will fire up fine.
During the day, everything seems to work fine.
I've switched to another thermostat JUST IN CASE, but it's pretty much the same result.
The AC worked fine all summer. Hmmm.
Thanks.
sabos is offline   Reply With Quote
Old 11-08-2010, 11:57 AM   #2
Rewards Points: 590
What make(s) and model(s) of thermostat? What make and model of furnace?
operagost is offline   Reply With Quote
Old 11-08-2010, 12:20 PM   #3
Lennox furnace and Hunter thermostats.
thanks for replying.
Old 11-08-2010, 12:35 PM   #4
Sorry.
I realize that's not a lot of info, but I'm at work and did not bring the info with me.
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
New Honeywell thermostat connected to old Climatrol heat pump olorintf HVAC 0 08-24-2010 09:52 AM
Moved thermostat - Now no heat. Bernan HVAC 2 11-15-2009 12:16 PM
Heat kicks on without thermostat bgd73 HVAC 1 05-23-2008 08:17 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
