Heat On Cool - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2013, 09:59 PM   #1
Rewards Points: 109
heat on Cool
I just replaced my Honeywell thermostat with a Trane and now my heat comes on when set to cool..
I tried switching the Orange and White and it is still happening.. Is there a reason for this happening? I'm starting to sweat a little, and the wife is not helping..
I originally setup the new one going off the chart here on page 6
Old
New
mchipser is offline   Reply With Quote
Old 10-30-2013, 10:09 PM   #2
Rewards Points: 12
Look in your furnace and see how the wires are connected. Match them to your thermostat and hopefully it works.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
gregzoll (10-30-2013)
Old 10-30-2013, 10:10 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
do you have a heat pump? Did you program the stat for your type of system in the installers setup? Reread the manual.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Old 10-30-2013, 10:11 PM   #4
An old Tradesmen
Rewards Points: 6,560
Did you go to 18C and set I to heat. If so, change it back.
Old 10-30-2013, 10:17 PM   #5
Rewards Points: 109
I just saw that in the manual
I don't think my system is a multi stage even though I have a Y2 label.
Also should the Orange go to W2 (like i originally had it) or W1
Old 10-30-2013, 11:04 PM   #6
Rewards Points: 109
This is the thermostat I am coming from..
http://hpgavin.pratt.duke.edu/DFM/HoneywellRTH7400.pdf
Old 10-30-2013, 11:22 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
Old:
R (and RC): 24 volts via red wire
orange wire to W for heat pump/first stage heat
white wire to w2 for second stage heat OR auxilary/back up heat/emergency
Yellow wire to Y for cooling
Green wire to G for "fan on"
blue wire on C is commaon
For new stat:
red wire to 2-1c (opposite where it is now)
and switch w1 (white wire)
and w2 (orange)
Green wire is still to G
Thanks.
Doc Holliday is offline   Reply With Quote
Old 10-30-2013, 11:27 PM   #8
Rewards Points: 109
Originally Posted by Doc Holliday View Post
Old:
For new stat:
and w2 (orange)
There isn't a 2-1c on the new one..
Old 10-30-2013, 11:31 PM   #9
yuppers, I read that wrong. It's 24c, top right, where you currentl;y have the blue common wire. that is where the 24 volts from the furnace allows the stat to be a switch, where the red wire belongs first and foremost so the stat can switch calls as needed.
I want a service fee...
Thanks.
Old 10-30-2013, 11:33 PM   #10
Rewards Points: 109
Then where does the blue wire go?
Old 10-30-2013, 11:56 PM   #11
Rewards Points: 109
I pulled all the wires out and it looks like the blue wire wasn't in the slot correctly.. I reset the blue wire and it is working now..
Thanks for the help guys!!
Old 10-31-2013, 12:09 AM   #12
good.
Thanks.
Old 10-31-2013, 12:16 AM   #13
Rewards Points: 109
Once i added it to my Zwave system is started to not work again..
Old 02-18-2014, 09:28 PM   #14
Rewards Points: 109
So it stopped working a few months ago, and i didn't worry about it since it got cold outside.. Now that it is warm again I'm freaking hot.. I put the old thermostat back on and it still isn't working.. It fan does kick on, but the compressor does not. I checked the fuse in the air handler and it wasn't blown.. I did have the compressor changed last year, it shorted out, anything else i can check before I call the AC guys out again?
Trane Heat Pump Problems (heat instead of cool) leesimmonds HVAC 12 03-22-2011 05:23 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 09:30 AM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Is there a way to have heat, cool and fan all on same blower speed? pirateo HVAC 4 08-14-2009 05:13 PM
