Heat Coming On A Lot? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 06:48 PM   #1
Heat coming on a lot?
I just installed new electric central air & heat pump (previously ekectric bb heat and no a/c.) We started turning the heat on at night. It gets up to temp and shuts off as it should, but comes back on and seems to be running more then its off. Is this normal? Is it designed to operate this way? I would think if the thermostat falls a degree it would come back on until it reaches the set temperature again. But it comes back on without a change in temperature.
TSGR is offline   Reply With Quote
Old 10-14-2012, 07:35 AM   #2
Thermostats read in tenths of degrees even though the display is in whole numbers. Make sure the hole behind the thermostat is filled. Some of them also have CPH settings or differential settings that can be adjusted.
Strange sound coming from the outside unit on Trane Heat Pump berr3555 HVAC 6 09-30-2012 09:05 AM
Extreme heat coming through Bay Window mwha1389 Building & Construction 9 06-23-2011 01:07 PM
Heat not coming on in the morning. garzaglass HVAC 2 01-26-2011 06:57 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
