Heat or Air won't turn off from Thermostat
Originally Posted by tdsilk
Yes, that was a day or two of drama with the new t-stat. What's funny is I work in tech support and often times run into problems customers could have
easily solved by reading the manual a little closer. I definitely have a better understanding about how the system works now.
I can top that. It took someone to come over and swap the input on one of co-worker's monitor. All day she sat there thinking it was shot.
The lcd screens we have are widescreens with two video inputs.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
