Heat Or Air Won't Turn Off From Thermostat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 11:37 AM   #16
thermal-medics.com
got it
what I meant by 'programming' was after wiring the new thermostat did you have to internally program ( run thru menus etc) for the type of system you have (heat pump) and if the reversing valve is energized in cooling or heating. I was just curious on this as they can be confusing at times.
good luck and let us know how it comes out
one last ? when it says on and runs and runs (if you remember or if it happens again) is the air coming out of the reigsters, say in your room, hot/very warm or just room temperature-ish. that says a lot
thermal-medics is offline   Reply With Quote
Old 02-28-2012, 12:16 PM   #17
HVAC Tech/ Browns Fan
6. offered to replace tstat for $220 (u kidding me!!!). YOU GOT TO REMEMBER WE DON'T DO IT FOR FREE ( u kidding me!!!)
Tator1076 is offline   Reply With Quote
Old 02-28-2012, 02:24 PM   #18
It comes out very warm. No comment on the $220 t-stat install -lol
Thanks for the input.
tdsilk is offline   Reply With Quote
Old 02-28-2012, 04:38 PM   #19
An old Tradesmen
Rewards Points: 8,154
If you have a heat pump with electric aux heat. unless you can lock out the aux heat, you should not be setting the temp back, as it can cause you to have a higher heating bill then you should.
Old 02-29-2012, 11:31 AM   #20
Every since the heat went off two days ago I haven't been able to get it to come back on. So far I've tried the new t-stat and the old. Whether I turn it to Heat, Cool, or fan nothing happens and it's a simple wiring setup. I wonder if a fuse has blown? Any ideas would be most helpful? The last time the unit was on it shut off by itself. I really don't think me lowering the heat had anything to do with it turning off.
Old 02-29-2012, 01:50 PM   #21
maybe if u apologize to Tator1076, he will remove the hvac HEX from your equipment....
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
Tator1076 (02-29-2012)
Old 02-29-2012, 02:05 PM   #22
There may be some truth to that - LOL
Old 02-29-2012, 04:01 PM   #23
thermal-medics.com
blahhhhhh
at the tstat. Touch green and red bare wires together. No fan still? nada zip, nil???
Reset breakers on Air handler. do it again - still nada??
Open air handler look for 5a fuse if you wanna go down that road
Best case blown fuse - worst xfmr popped
all of this after you are sure you have eliminated wiring at t-stat, temp control, programming etc.
good luck
I like the $220 hex
The Following User Says Thank You to thermal-medics For This Useful Post:
hvac5646 (02-29-2012)
Old 02-29-2012, 06:12 PM   #24
good luck
I like the $220 hex
Thanks for the info. I checked the red and green connection and nothing happened. I will check the air handler next. I know there is a circuit box (gray box w/ a black plug at the top) about 10 feet from the air handler. Is this the breaker you're referring to or is there another breaker on the air handler itself? I appreciate your expertise.
Old 02-29-2012, 09:16 PM   #25
thermal-medics.com
main breaker
By touching the red and green you are just trying to confirm that you have 24volts still coming in to the thermostat, basically 'hot-wiring' your fan. You said nothing happened so that would take you next...
I was thinking of the main breaker at the box for the air handler - reset
longshot but try the red and green again together...
then if nothing:
The fuse I was refering to is (typically) in the air handler along with the transformer. If you are brave enough to dive in and look, this is where you will find the the suspects.
tdsilk (02-29-2012)
Old 02-29-2012, 09:23 PM   #26
Thanks. I'll look in the Air Handler tomorrow. I will just make sure the circuit breaker is off. I'll keep you updated. I'm hoping it's the 5a fuse. Luckily, it will be 78 degrees here tomorrow.
Old 03-01-2012, 02:28 PM   #27
5amp fuse was blown in air handler. Replaced the fuse and unit and red to green kicks fan on. Hopefully, all will be fine when t-stat is installed. Thanks for all the help.
Old 03-03-2012, 06:14 AM   #28
did you get it working correctly? typically the carrier/honeywell comination if you purchased a heat pump t-stat would be red to Rc jumpered to Rh green to G terminal(fan) orange to O/B (reversing valve) white to W2/aux jumpered to E emergency heat (heat strips) yellow to y/y2 (cooling) blue to C (common) this wiring is at the t-stat but could vary slightly with how the air handler and condenser wires are wired. so first check the colors that are wired to the condenser then the check that they match the wiring in the air handler then the t-stat
rsarg is offline   Reply With Quote
Old 03-05-2012, 11:28 AM   #29
Looks like I spoke prematurely. I haven't confirmed it yet, but I think the fuse blew again. I say this because I installed the t-stat and nothing turns on.
I removed the t-stat and tried the GREEN to RED wire test again and this time no success. I will check the new fuse to confirmed that it's the problem,
but my guess it that it is. If the fuse has blown again is there something else I should check?
Old 03-05-2012, 02:34 PM   #30
Hey tdsilk.....Tator is waiting to take away the HEX for a nominal fee
Replacing thermostat, no heat (heat pump, 2 stage heat, 1 stage cool) BrianJM HVAC 20 09-28-2011 09:53 AM
New Thermostat for Heat and A/C will1874 HVAC 1 07-12-2011 05:03 PM
Thermostat with separate fan and heat relays Steve-P HVAC 9 11-12-2010 04:46 AM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 02:21 PM
Hunter 44668 Thermostat - Heat won't turn off ToneyRes HVAC 9 10-18-2009 08:50 PM
