Heat/Air Won't Cut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 09:47 AM   #1
Heat/Air won't cut off
I have an electrical hvac unit. Handler is in the attic, and I have an outside unit. My unit has 2 zones. The units are 6 years old, I have already replaced the outside unit and the capacitor in the attic air handler. If I place the thermostat upstairs on heat and set it to 70 and have it on auto, it won't cut off...it will be 80 degrees upstairs. If i set the downstairs thermostat to auto, heat and 70 it will be 80 degrees downstairs and 85 degrees upstairs. Any other info anyone needs? I look forward to responses.
bradmivan is offline   Reply With Quote
Old 01-22-2013, 03:37 PM   #2
Do you have a volt meter? If so check at the air handler and see if a control is telling the heat to run or if a sequencer is stuck. Voltage at W and C on at the air handler would mean the thermostat or zone control is telling the elements to run.
Old 01-22-2013, 03:42 PM   #3
I have a multimeter. Where would I place my prongs? I have LED lights on the zone unit and it shows that the heat or ac is on even when my thermostats are off.
Rheem heat/air unit scott collins HVAC 3 01-06-2013 08:32 PM
Carrier Central Heat/Air Unit acting strangely TheWilldog HVAC 4 02-16-2011 06:42 PM
how do I connect the heat/air condition vent to the toe kick? aim2050 HVAC 1 10-22-2010 10:46 PM
Hydronic heat/air handler concern duster HVAC 2 03-24-2010 09:57 PM
