Heat And Air Conditioner On A Boat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 11:54 AM   #1
Rewards Points: 150
heat and air conditioner on a boat
hey I have a marine heat pump system that runs on r 22. the problem is the thermostat is old, and I want to put a new digital thermostat there. the problem is the control voltage on the boat is 120 volts not 24 volts. but the compressor and air handlers are120 volts. can't I add a transformer and change out the relay and make this thing work?
thanks for all your help
wetbar is offline   Reply With Quote
Old 11-30-2011, 12:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,066
Ayuh,... Maybe....
Probably easier to just get a 120v T-stat...
Old 11-30-2011, 03:30 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
I agree
http://www.luxproproducts.com/program.html
They have a line voltage one for heating. Have never seen one for AC as there are no 110 volt AC tstats that I have ever seen. You can do it with a transformer and relay but may run into liability issues if something goes wrong.
Old 11-30-2011, 03:46 PM   #4
biggles's Avatar
could add this relay http://www.bestbuyheatingandaircondi..._Code=REL90123 might want to add a time delay with it being 120V along with that TR 40VA 115/24.if you go with the 24V change ton of setback stats are there with wake/leave/return/sleep..if you just want 2 setbacks might hold off...120Vs are availible....
