Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2009, 10:33 AM   #1
heat
My lennox was not defrosting so I replaced my defrost board and it still will not go into defrost, could it be something else?
cobra32425 is offline   Reply With Quote
Old 01-31-2009, 11:44 AM   #2
An old Tradesmen
Rewards Points: 7,832
Sure.
Could be the defrost sensor.
Depending what model, it could be the OD temp sensor.
Or the RV coil.
What did you check, to determine it was the defrost board.
Old 01-31-2009, 11:56 AM   #3
hi, i bought a new furnace, the old furnace up flow opening is 15x18 ins. and the new furnace is 12&half x 19 ins.the space between is18 ins minus half ins. on 18 ins to make a lip . mike
kaishu10 is offline   Reply With Quote
Old 01-31-2009, 04:28 PM   #4
An old Tradesmen
What made sense to you while typing, often losses something in the typed words.
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 03:57 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
