Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2008, 03:04 PM   #1
Heat
Ok guys. I have a two story home, over 2500 sq. ft. I heat with propane, hot water baseboard with two zones, one upstairs the other down. Should I be setting my thermostats at different settings, upstairs vs. downstairs. My husband thinks they should be set at the same setting so all the downstairs heat will not rise?? I am confused..please help..ALso I think I need some insulation in the attic as my upstairs does not stay warm..Thank you....
jennfran is offline   Reply With Quote
Old 11-18-2008, 03:44 PM   #2
Rewards Points: 1,910
Set them to the temperature you want the zone to be.
Heats gonna rise regardless of what they are set to. Setting them the same won't stop it.
Insulation is the most cost effective way of making your home comfortable and less expensive to heat/cool so if you need more add it.
Old 11-18-2008, 03:49 PM   #3
Thank you Jogr! So it will be ok to set my upstairs lower since I am not upstairs that much during the day?
I have a three yr. old home but lets just say I do not trust the previous owner who built the home. I do not have an attic nor a crawl space so I am going to cut out a section in a closet and see what is up there for insulation. Thanks again..
Old 11-18-2008, 04:37 PM   #4
Having no attic can certainly complicate adding insulation. Or maybe you just don't have an attic access panel? Do you have a flat ceiling upstairs or vaulted? Looking at the roof from outside is it flat or is it sloped? If sloped about how much higher is the peak of the roof compared to the height of the roof where it crosses over the exterior wall?
Old 11-18-2008, 07:58 PM   #5
Yup, can't get around the laws of physics.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-19-2008, 04:36 AM   #6
An old Tradesmen
Rewards Points: 6,544
NOW you tell me.
Zoning is done for multiple reasons.
1. To ensure that an area reaches a desired temp.
2. To economize system operation(why heat an area to 70 that isn't being used).
3. To keep up with the neighbors.
Old 11-19-2008, 10:19 AM   #7
Originally Posted by beenthere View Post
NOW you tell me.
Have you figured that gravity thing yet?
Old 11-19-2008, 10:10 PM   #8
An old Tradesmen
I'm still reading the report on it.
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Help with Air Handler and Aux Heat kulkarni_ash HVAC 5 10-06-2008 09:05 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
