Headroom - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2008, 12:54 AM   #1
Rewards Points: 83
headroom
Hey all,
What can I do to this to gain some headroom? 7' cielings, duct work knocks it down to 6'3".
rodsteryz is offline   Reply With Quote
Old 12-22-2008, 06:32 AM   #2
An old Tradesmen
Rewards Points: 7,802
Not much.
If the supply duct isn't againt the joist, its because they are preventing expansion noise from being transmitted through the joist.
Your duct is 8" high.
To use 6" high duct.
An 8 x 18, would have to be replaced with a 6 x 28
Gaining you 2" more head room at teh area the old duct work takes up.
But loosing 6" on an area 10" wider. And if you change both ducts to 6" high duct. You loose head room in a larger area yet.
Old 12-22-2008, 08:17 AM   #3
1610 CUB's Avatar
Rewards Points: 150
Can you move the furnace to a more central location in the basement? If that were a option the ducts could be sized in half. Like a 5X15 each way........... but a lot of work for little in return!
1610 CUB is offline   Reply With Quote
Old 12-22-2008, 09:30 AM   #4
Grow shorter
Not much you can do other than what has been suggested: swap in shallower ducts but maintain surface area; or move the furnace.
dac122 is offline   Reply With Quote
Old 01-02-2009, 12:11 PM   #5
Rewards Points: 83
Thanx, I thought that was the answers I was going to get. Pics don't show it very well but the heater does set in the middle. I may have to change my floorplan for the 100th time!
