HCAC Drain (Into Septic) - HVAC - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 03:11 PM   #1
I have a Carrier Heat Pump Infinity and I have been having problems with the AC Unit possibly over loading the The Septic Field with too much water , We live in the Houston Tx Area where there is a lot of Humidtiy , First Question is Anyone know the maxium amount of Gallons of water that would drain out in a 24 hour period .
And second what can I do if I need to reroute a new pumbing line into the attic and then out into a drainage pit outside and off of the septic line ?
The AC Unit is on the First Floor Center of Home .
tbarnes is offline   Reply With Quote
Old 04-16-2013, 03:19 PM   #2
An old Tradesmen
Rewards Points: 8,154
Gallons per day depends on size of unit, plus amount of infiltration the home has. So what size is your A/C.
Old 04-16-2013, 08:49 PM   #3
chitownken's Avatar
Rewards Points: 510
Your septic field should be able to handle several hundred gallons of water per day. Your evaporator drain would have to be running like a faucet to overload a properly working septic system. You might need to have you septic system inspected and/or pumped if your A/C is overloading it.
chitownken is offline   Reply With Quote
Nasty Septic gas smell from concrete floor Muggle Plumbing 2 02-20-2013 09:34 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Removing washing machine drain from septic 12172003A Plumbing 2 07-25-2009 05:32 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
