Having Trouble Brazing - Not Hot Enough - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 11:04 AM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 398
it helps a LOT to use plumbers sandcloth to clean the copper down to where it is not oxidized also. weld has to be done quickly or like solder the material will start to transfer/run down the pipe and get lumpy and a mess to fix later. practice makes perfect and turbotorches work OK for regular fittings but take too long and will cook/damage a service valve. depends on the skill of the tech but not recommended for fine work.
brazing filler for A/C lines taxmantoo HVAC 2 07-04-2013 09:50 PM
Welder Trouble BuB901 Electrical 4 05-25-2012 01:39 PM
Brazing Technique JJboy HVAC 10 03-07-2011 06:20 PM
Left a kleenex in suction line while brazing tesla500 HVAC 0 07-13-2010 10:19 PM
This brazing rod good? integlikewhoa HVAC 10 12-27-2008 07:00 PM
