Have Heating Ducts In Basement Ceiling Leave Or Move? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 12:56 PM   #1
Have Heating ducts in basement Ceiling leave or move?
I am remodeling my basement. I only have 2 ducts that blow into the basement area and they are in the ceiling between the joists. One on each side of a 25 x 26 area.
Should I move them to the wall? or they fine where they be?
If so how do go from a 6" duct to a stud wall space?
jdtox is offline   Reply With Quote
Old 10-04-2012, 01:34 PM   #2
Experienced
Jackofall1's Avatar
I would move them to the outside walls of the room as well as add a couple, I would also add a return air grill in the room.
Mark
Old 10-09-2012, 06:04 PM   #3
Rewards Points: 266
Having experienced heat in the ceiling of a basement, I would move them even if it is difficult or somewhat costly. I've practically frozen to death in that situation.
What is the stud spacing? You should be able to make the transition from round to square ducts with no problem.
Does the system cool as well? If so, you could keep the ceiling vents for summer and close them off for winter and vise versa.
ionized is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Sound Deadening Basement Ceiling darrylshill Drywall & Plaster 4 06-01-2012 06:01 PM
Basement framing - drywall ceiling question tmhouse Building & Construction 1 07-11-2011 12:11 PM
Drywalling my basement ceiling luweee Remodeling 5 03-24-2009 06:58 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
