Have Heat But Ac Wont Come On - HVAC - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 10:27 PM   #1
Have Heat but ac wont come on
Hello all this is my first visit and post. Im sure you guys can help so heres the problem. I have a heat pump, (package i guess, its all outside). Im not a pro at this hvac stuff yet, but can change stat, capacitor and motors and such, but am confused about this. I can turn the heat on and the unit runs fine, no issues at all with heat. When i switch to ac, I get nothing but the blower fan in the unit. If the capacitor was bad, wouldnt it stop the compressor from running in the heat and ac position?
quickbrad is offline   Reply With Quote
Old 05-05-2011, 10:31 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Yes. Are you saying the compressor is running in cool mode or not running?
Doc Holliday is offline   Reply With Quote
Old 05-06-2011, 05:44 AM   #3
An old Tradesmen
Rewards Points: 6,468
When in heat mode, did you actually see the outdoor can running and hear the compressor running, ot did you just check for warm air at the registers?
Old 05-06-2011, 12:51 PM   #4
Yes i can see and hear that the compressor is running in heat mode. Also I have hot air coming from the vents. It just will not run in cool mode, only the blower fan runs, I have room temp air coming from the vents, and the compressor or fan do not run. Its very confusing.
Old 05-06-2011, 12:54 PM   #5
Compressor is not running in cool mode. I have air coming from vents but its just room temp air. No matter where i set the stat, the compressor will not come on in cool mode.
Old 05-06-2011, 03:54 PM   #6
An old Tradesmen
The call/signal for the compressor to run comes through the same wire for heat as it does for cooling.
Its possible that your unit has a low pressure switch, and its shutting the outdoor unit down in cooling mode because the pressure is too low.
Old 05-07-2011, 06:40 PM   #7
low pressure?
Old 05-07-2011, 06:49 PM   #8
low pressure?
Low refrigerant pressure meaning low on refrigerant as in possible leak. Protection for the compressor so it doesn't run dry and burn itself out.
Refrigerant level needs to be checked to determine if that is a possible cause.
Old 05-08-2011, 07:40 PM   #9
have you changed your thermostat recently and now you have a problem
mrairflow is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
