Old 05-06-2012, 10:48 AM   #1
HAVC unit won't come on
This morning I noticed that my main floor wasn't cooling. I checked and found the condensation pump full ( little giant model VCMA-15ULS ). I disconnected the hose from the unit to the pump, drained it, dumped the pump and reconnected it.
The aprilaire 8446 display unit clicks when I turn down the temperature but the hvac unit itself ( model FA4CNF030, doesn't show manufacturer ) never comes on. I've tried turning the circuit on / off at the power panel.
I also tried swapping out pumps with another and disconnecting the switch that is in the pan at the bottom of the unit for condensation flooding. Each time I powered the unit off and even hit reset on the aprilaire control unit at the wall.
What else can I do to try and get this puppy to come alive?
atlacfence is offline   Reply With Quote
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 05:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 04:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 08:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 10:33 PM
