Has Anyone Used The Quiet Fence? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 10:29 AM   #1
Rewards Points: 152
Has anyone used the quiet fence?
Hi All,
http://quietfence.com/
This is not a plug, I just saw this when googling how to reduce the noise of my condenser. My unit is very annoying while sitting on my patio.
Any other ideas that would work to reduce noise levels?
sandyman720 is offline   Reply With Quote
Old 07-28-2011, 10:34 AM   #2
JJboy's Avatar
Compressor cover is better.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-28-2011, 10:50 AM   #3
Rewards Points: 152
Wont that reduce efficiency since it reduces the airflow?
Old 07-28-2011, 11:00 AM   #4
JJboy's Avatar
The cover is just for the compressor, not the whole condenser.
Old 07-28-2011, 11:39 AM   #5
Rewards Points: 152
Do you have a picture or link?
Old 07-28-2011, 11:46 AM   #6
JJboy's Avatar
http://www.brinmar.com/sound_blankets.html
Old 07-28-2011, 12:38 PM   #7
Rewards Points: 6,652
My neighbor to the right of me has a Lennox that is very quiet, mine is a Armstrong air that is a little louder, then the neighbor to the left of me has a Lennox that is louder than all three together. A lot of the noise is air turbulence, and vibration of the line set. I used spray foam to seal the hole in the concrete block where the line set enters my basement to also help isolate vibrations.
Old 10-14-2011, 09:08 PM   #8
ruh
wont reduce efficency
The Quiet Fence works best when it's 12" away. That isn't blocking any airflow. Compressor blankets work well too, but may violate warranty, and require tools and some knowledge. Big plants don't do anything but clog up the a/c unit.
ruh is offline   Reply With Quote
Old 10-14-2011, 10:03 PM   #9
REP
Since there are several things that allow noise to escape from the condenser,there are several things that help in getting that noise level down.
Insulating around the spot where the line set enters the home is good as is making sure the line set is not installed tightly against any wall or joist with using plastic to hang it where needed.
The compressor will not require any specuial tools and will help quite a bit.
I also use vibro pad under the condensor where ever I can.
The fence should work if its made of a soft sound absorbing material.
Nothing says you can't do more than one thing.
What you are really talking about arwe things that good contractors do and can't explain when they are asked why they cost more than the other guy.Something to think about.
REP is offline   Reply With Quote
How to add a dividing fence to chain link fence and house with siding catburke Building & Construction 1 10-10-2013 12:33 AM
Backyard Fence (Part 1) biggidybankston Project Showcase 20 12-04-2010 11:44 PM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 08:05 PM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 06:03 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 03:39 PM
