Has Anyone Applied The Spray In Foam In The Attic Themselves? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-01-2008, 09:49 PM   #1
Rewards Points: 210
Has anyone applied the spray in foam in the attic themselves?
I've seen kits that you can do yourself and wondered if anyone has done it themselves.
What was the outcome?
imola ghost is offline   Reply With Quote
Old 09-02-2008, 12:46 AM   #2
Registered User
Termite's Avatar
I haven't seen Icynene-type foams in a DIY application, but will caution you about a couple things. Assuming you're wanting to spray the rafters??? Is the attic going to be heated/cooled? In my opinion, there's no other reason to do it.
First, blocking off your soffit's ventilation path to the remainder of the attic would cause lots of issues.
Second, a lot of insulators make the dangerous mistake of spraying the stuff up against furnace and water heater flues, and fireplace vents/chimneys. I see it shot into electric boxes all the time, and that is asking for problems.
Third, flammable foam plastics are prohibited in attics that can be accessed for the service of utilities (electrical, furnace, air handlers, plumbing, etc). Many spray foams are very flammable.
Old 09-02-2008, 01:36 AM   #3
Rewards Points: 210
All the ones I've seen are non flammable. They're made sugar, corn beets and some other renewable sources.
I've never seen this product done before but this one I believe you can do it yourself.
http://www.tigerfoam.com/
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 09:54 AM
DIY Spray foam insulation y2khardtop Building & Construction 3 01-12-2008 07:43 PM
Spray foam simonb Building & Construction 6 11-30-2007 08:11 AM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 11:14 AM
