Hard Wring Motor For 110 Volts AC - HVAC - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 12:32 PM   #1
jburd964's Avatar
Rewards Points: 166
Hard wring motor for 110 Volts AC
I have a squirrel cage fan that is unused. I'm wanting to wire it as a stand alone fan. I'm need assurance that i'm reading the schematic right. I'm seeing white is common leg to plug and black and blue the other two with orange and red connected only to each other. Is this correct? Sorry for image clarity.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 07-29-2013, 12:45 PM   #2
Rewards Points: 45
That is how I read as well...
L1 - White
L2 - Black/Blue
Connect Red/Orange together
RunningSparky is offline   Reply With Quote
The Following User Says Thank You to RunningSparky For This Useful Post:
jburd964 (07-29-2013)
Old 07-31-2013, 07:37 AM   #3
jburd964's Avatar
Rewards Points: 166
Speed control.
The fan runs fast and only takes in air through on side of cage that its really loud. I have other similar fan that I can rearrange wire to adjust fan speeds. Is there any way could it be done? I tried it by switching wire around on this one with no luck. Please give details?
Old 07-31-2013, 08:45 AM   #4
PoleCat's Avatar
Rewards Points: 1,638
That is a single speed motor so no joy there.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-31-2013, 08:57 AM   #5
jburd964's Avatar
Rewards Points: 166
Figured as much. have another in using in attic of house i'm flipping and going to switch them around.
Tags
electrical , motor , schematic , wiring
faucet hard to pull out? Leprichon Plumbing 14 11-15-2014 01:11 PM
Not getting 120 volts from hot to neutral, but 120 from hot to ground Jimmi328 Electrical 23 05-14-2013 10:00 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Wire sizing to the condensor zootjeff HVAC 9 06-22-2009 09:02 AM
changing 250 volts into 115 volts hottlilmama Electrical 9 05-25-2009 10:33 AM
