Hanging Furnace With DuctworK? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 02:25 PM   #1
Hanging Furnace with DuctworK?
I have a Reznor Hanging furnace in my garage, Model F50. I am going to be finishing the ceiling and I have an idea, but not sure if its possible. Is there any kind of conversion kit for the front of the unit that would allow me to run some flexible duct work (say 6" round) and then run it to a ceiling register with the same 6" connection in it? I found these ceiling panels, and I don't know if its okay to make a reducer in the front of the unit or not.
thanks for the help
hockeystewey is offline   Reply With Quote
Old 08-02-2011, 02:38 PM   #2
fabrk8r
fabrk8r's Avatar
It's not recommended to reduce the outlet size or impeded the air flow on a hanging unit heater, or any forced air heater for that matter.
The unit could overheat and not only be damaged itself, but could also cause a fire. At the least the unit will shut off on high-limit enough to be a nuisance.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-02-2011, 04:19 PM   #3
newtech's Avatar
Rewards Points: 164
thanks for the help
Here is the PDF. https://www.rezspec.com/index.php?pa...D=000000000002 I-F_B.. They don't have a conversion listed.
Is it a belt drive motor or a direct drive motor.
Please post the whole model and serial #..
The pdf I have was too large to post.
newtech is offline   Reply With Quote
Old 08-02-2011, 06:03 PM   #4
Full model on unit is F50-3. Serial is AWD31K5N29641
Thanks for the help
Old 08-03-2011, 07:04 PM   #5
Forgot to mention it is direct drive fan
Old 08-03-2011, 07:19 PM   #6
REP
Reznor makes units that are designed to be ducted but yours is not.The ducted ones usually have a squirl cage blower and not a propeller.
DO NOT TRY TO ATTACH DUCT TO YOUR UNIT.
fabrk8r is exactly correct.You could start a fire.But then at least you would be warm,,,,,LOL
REP is offline   Reply With Quote
need help with package unit ductwork bekind42 HVAC 15 11-04-2011 03:13 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
HVAC!! Furnace venting issues!!!!! HELP! Hurricane_Ditka HVAC 14 09-08-2010 01:58 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
