Old 06-26-2009, 07:55 PM   #1
Default Haier Portable AC Question
I have a Haier CPRD12XH7 12,000 BTU AC that I am using in my garage. The fan runs but it doesn't seem to be cooling. It has 2 hoses off the back. One is hot air exhaust and the other is a cool air return for the condenser. Both are vented out the side wall of the garage, each through a 4" dryer vent. The 2 vents are approx. 3 ft apart.
The manual lists the operating temp range at 41F to 95F. Does this mean if the temp is above 95F it won't kick in? It's currently 97F. It's a new unit and when I was venting it under the garage door, it worked fine...it didn't keep up but it was cooling.
Peace,
Mark
guitarnut is offline   Reply With Quote
Old 06-26-2009, 08:24 PM   #2
Default Solved
OK, actually, not solved. It runs for a few minutes then the compressor shuts off...just blows warm air. I'm not sure what's going on.
Pics of the setup:
http://www.crenshawweb.com/ac.htm
Peace,
Mark
Old 06-26-2009, 10:43 PM   #3
Yoyizit's Avatar
Does it turn off because its reached the setpoint?
Yoyizit is online now   Reply With Quote
Old 06-26-2009, 11:41 PM   #4
JohnH1's Avatar
1st.Try pulling th unit away from the wall the streighten the hoses. they may be to restrictive bunched up like that.
2nd the vent covers on the outside may also be redusing air flow to much they act like a additional elbow and remove the flappers if they have them. most of the units I have seen do not utilize a hood on the outside only a stright pipe with maby a bug screen.
Good luck
JohnH1 is offline   Reply With Quote
Old 06-27-2009, 01:21 PM   #5
Nope. The shut off point is 78F...the room is around 89F.
Peace,
Mark
Old 06-27-2009, 01:24 PM   #6
Good luck
Hi. Thanks for the suggestions. I have determined that the blower is shutting down, causing the compressor to exceed operating temp, then it shuts down. Haier is sending a tech out to look at it this Wed. I'm thankful they offer on-site for the first year.
Peace,
Mark
Old 06-27-2009, 01:29 PM   #7
Yoyizit's Avatar
Sounds like an overtemp sensor embedded in the blower motor windings is shutting off, for a good reason or not.
Old 06-27-2009, 01:57 PM   #8
Hi. Thanks!
The blower is not coming on at all now. I guess the tech will figure it out.
Peace,
Mark
More On This Topic
One of the biggest challenges in maintaining a greenhouse is humidity control. Most plants enjoy a humidity of 50 to 60 percent, and this is a challenge to manage at times. The main goal is to avoid condensation on plants, which promotes mold and fungus... Read More »
Common French Phrases for Talking About the Weather Bonjour, my name is Stéphanie with Expert Village, and today we will be learning to speak French. WEATHER How is the weather today? Quel temps fait-il aujourd’hui? Is it cold? Fait-il froid... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. So we have the compressor that compressed the refrigerant to a high pressure gas that went through the line. Now it goes through the condenser. In this condensor unit, it's like a... Read More »
I'm Chad I present motorcycles in Wilmington, North Carolina on behalf of expertvillage.com I'm here to show you some of my maintenance on our bike before you go out for a ride. Now we are going to talk about some of the tools that we use today that you... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. Leaks can occur from any part of the system. The compressor may be kicking on but it could be leaking. It's a major source for leaks as are the lines. The condenser is exposed to... Read More »
Portable saw Question Gettingintoit Tools 10 11-03-2008 09:45 AM
Basement Renovation Question KUIPORNG Remodeling 235 08-26-2008 10:19 AM
hrv question indep HVAC 3 07-18-2008 12:39 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 11:10 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-12-2007 12:17 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
