H/W Pro 500 Shorth Cycling On Cool Cycle - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2013, 04:24 PM   #1
Question
H/W Pro 500 shorth cycling on cool cycle
I have a customer that is complaining that her Pro 5000 t'stat we put on a month ago worked great at first. It ran for 20-30 min & went off for 20-30 min. Yesterday it started running for 20 min. or so then off for 5 min then back on. A/c is working great, refrigerant is on the level. Replaced t'stat with a Pro 3000 & have same trouble. Any advice?
drummbob is offline   Reply With Quote
Old 08-20-2013, 04:38 PM   #2
An old Tradesmen
Rewards Points: 7,786
What is the CPH set to.
Old 08-20-2013, 05:49 PM   #3
It is set to factory 3. Wonder what changed to make it cycle more frequently. Would it help to change it to 1 or 2?
Old 08-20-2013, 06:26 PM   #4
An old Tradesmen
Changing to 2 will help some.
Is/was it cooler yesterday and today then the previous 30 days, or warmer. look for things that may have changed in the house. Any type of new work since the A/C was installed.
Tags
a/c short cycling , pro 5000
Heating Cycle Rate, mid efficiency. pete0403 HVAC 4 03-25-2013 07:52 PM
Coleman 8665D766 short cycling during cool down dl_sledding HVAC 2 10-18-2012 02:47 PM
Pool deck cool deck chalking hammmer13 Building & Construction 5 12-01-2011 08:32 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
Reducing BTU's tedhermitage HVAC 11 10-28-2009 05:55 PM
