-   -   gurgling in baseboard heat system (http://www.diychatroom.com/f17/gurgling-baseboard-heat-system-6616/)
jpg 02-20-2007 08:13 PM
I had to replace my water heater and when I did I turned the water off at the main inlet. Now I notice that I am getting a gurgling noise in my baseboard heater system. I can hear the water rushing thru the lines. I have 2 apparant bleeds in the piping by the boiler which I attached a hose to and bleed them. Do I do this with the power switch off to the boiler? Do I need to bleed each baseboard as well? Help. JPG
redline 02-22-2007 07:56 PM
You have air in the system. You will need to bleed each zone for air. Make sure that the system is getting new water into the system.
