Ground - HVAC - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 10:56 AM   #1
Ground
Hey guys new here i had a guy test my A/C out would not start he used a voltmeter and there was no volts coming in (line side single pole contactor) but when he put one probe on contactor and the other probe
to the cabinet(ground) he read 120v each side i dont remember what this ment but just curious if you have no power coming in to unit but 120v to ground what does this mean is there voltage somewhere or is 120v to ground just saying its grounded to the unit. I appreciate your help in expalaning this to me
Tony vargas is offline   Reply With Quote
Old 04-13-2011, 11:09 AM   #2
HVAC Tech/Owner
Rewards Points: 604
It is 120 volts to ground on each side, 180 degrees out of phase to get 240volts across both. Did he fix it?
Technow is offline   Reply With Quote
Old 04-13-2011, 01:08 PM   #3
Ground
Yes it was a breaker was tripped . i am not sure what you mean by 180 degrees out of phase to get 240volts can you be more laymans terms. can you touch the wire 120 v to ground , is there voltage there that can hurt you with no power (240) coming in, thanks alot for your time
Old 04-13-2011, 03:01 PM   #4
An old Tradesmen
Rewards Points: 7,764
Voltage was coming in. But it was only coming in on 1 leg. So when reading across both legs it chowed no voltage because it had no return path. And yes, it can hurt you when only one leg has voltage.
Old 04-13-2011, 03:23 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
yes, that 120 volts will kill you just as fast as any other 120 system. You have the same power at that point as you would with a wall outlet.
Old 04-13-2011, 04:10 PM   #6
Awesome i get it now thanks for clarifying you guys been very helpful , great forum have a good day......
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
