Green Light - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2013, 04:52 PM   #1
green light
cleaning my heat pump and it is not cooling. a green light is flashing inside my heat pump. is that green light flashing indicating a problem and what has to be done to fix it
ragityman is offline   Reply With Quote
Old 01-09-2013, 05:01 PM   #2
Rewards Points: 13,996
No make, model, and not enough info.
Old 01-09-2013, 05:50 PM   #3
Roofmaster
Rewards Points: 2,210
Do you mean that your heat pump stopped pumping cool air, so you decided to clean it, and now the control board is showing a blinking green LED?
Since different manufacturers use different colored LED's, different error codes, dont you suppose that Size, Make, Model Number, Version, Serial Number, and board SN would help, along with where you live?
Pictures help a lot too because some of the guys here are really sharp, and know a unit on sight.
These Forums never cease to amaze me.
Old 01-09-2013, 05:59 PM   #4
An old Tradesmen
Rewards Points: 7,808
Brand and model number would help. usually if its a steady flash it means all is normal and it is receiving no signal for heat or cooling.
Old 01-09-2013, 06:21 PM   #5
Roofmaster
So his battery is dead in his T-Stat?
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Ceiling fan light kit duhtroll Electrical 10 06-21-2011 02:29 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
