Got New Thermo - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 02:14 PM   #1
got new thermo
got a honeywell RTH110b now my question the cycles per hour on these what should it be set to 4 is default it goes from 2-6. 4=15 min what do they mean runs 4 times in 15 min then 5=12 6=10 or 3=20.Now the heil 5000 furance are they 80% or 90% from what honeywell says if it is 90% drop it to 3 and if it is less the 90% keep it a 4 now i timed the burner comes on 4minutes shuts off the fan will blow for over a minute then the burner will light back up for 4 minute then go off then the fan blows the rest of the heat out.Shuts down for a few more minutes and it starts over again.Now thats the way it should run right.It's about 15deg where i'm at
harley75 is offline   Reply With Quote
Old 01-17-2009, 04:12 PM   #2
An old Tradesmen
Rewards Points: 6,112
One cycle is the on time plus the off time.
So 4, would be on, say 7.5 minutes and off 7.5 minutes, for a total of 15 minutes per cycle.
Although it won't be those actual times most of the time.
Old 01-17-2009, 04:54 PM   #3
ok so then we are at normal run the way it should be
Old 01-17-2009, 07:41 PM   #4
An old Tradesmen
I set both 90, and 80% to 3 CPH.
But, no harm in using 4 on a 80%.
Old 01-17-2009, 10:14 PM   #5
On 4 good but after it shuts off on the last run before it comes back on you get a we bit chilly then it kick back on
Old 01-18-2009, 06:32 PM   #6
Now that i got the tstat where i want it the draft blower is screaming sounds like it going to lock up.I lubed it up hope it hold up till tomorrow till i get a new one
Old 01-18-2009, 08:25 PM   #7
An old Tradesmen
Good luck.
Is the gas valve bad? Gargecko HVAC 23 10-12-2008 11:34 PM
2 Stage AC with older Furnace? SteveTheBuilder HVAC 5 07-18-2008 09:04 PM
