Old 06-30-2010, 02:28 AM   #1
goodman split a/c
as a 'rule of thumb' what back pressure would you see on a 18000 btu condensing unit R-22 type if it was working ok in cooling mode...Thnx's
Jacques is offline   Reply With Quote
Old 06-30-2010, 06:48 AM   #2
goodman split a/c
To many variables to put a pressure on it depend a lot with the temperature outside and the temperature inside, the fan speed, how clean the coils are, and many other things. But on a hot 90degree day an average back pressure should probably run about 68LBS. Please don't hold me to it like I said to many variables.
COLDIRON is offline   Reply With Quote
Split System Replace, Resell? golddog HVAC 3 06-25-2010 04:38 PM
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 03:32 PM
Repairing Split in Wood Door? diyintexas Carpentry 4 10-11-2009 02:00 AM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 04:52 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
