Goodman & Roll Out Switch Issue? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2007, 03:53 PM   #1
Goodman & Roll out switch issue?
I am baffled by why, when I bump down the temperature setting (when heater is running) on the thermostat that the roll-out switch trips, but does just fine if I leave the switch alone. My thinking is that there should be no difference. Lowering the temperature setting should the same as if the inside temperature got to the target and the unit shuts down normally.
wsquared is offline   Reply With Quote
Old 11-10-2007, 11:12 PM   #2
Have someone else shut off the thermostat whyle you are viewing the burner area. If you dont get any flame rollout your switch may be bad. If you do, you have a flue or combustion supply problem. Be sure you have proper combustion supply air vents to the furnace room, if you have a combustion blower check to see if it needs oil and check the amperage with the rated amperage to see if it needs replacement. If it is an atmospheric, check the draft hood with a match to check draft.
shawn T is offline   Reply With Quote
goodman pressure switch error 3 blinks mrbac HVAC 4 03-11-2013 11:43 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
