Goodman Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 06:36 PM   #1
Rewards Points: 484
Goodman question
Hi all. I just brought home a Goodman gas pack that is about 3 years old, 3 ton unit.
I hooked it up to test run it in the garge and noticed that the lower 1/4 portion of the evap coil does not get cold. Is that usually a low charge indication, or would it be a restriction? Thanks.
sammy37 is offline   Reply With Quote
Old 07-21-2012, 06:51 PM   #2
In my experience package unit don't usually leak and thus don't need refrigerant added to them. Sadly most leaks in systems come field connections by us contractors in the refrigerant lines. This only holds true for newer equipment. As the equipment ages the components will degrade and leak.
If the unit is running in a garage the coil may not be completely cold due to the temperature entering the coil. I find system when first repaired or installed new and the home is extremely hot and humid the system sometimes act a little strange until they began to cool and dehumidify the space.
Your package unit sitting in the garage being test ran will never cool the space to allow for testing as all the heat you are removing from the space will be rejected back by the condenser fan.
turnermech is offline   Reply With Quote
Old 07-21-2012, 07:00 PM   #3
Rewards Points: 484
I understand. I have tested a few units in the garage before but never in this kind of heat and humidity. It just seemed funny that all but the bottom area of the coil gets cold.
Old 07-21-2012, 07:07 PM   #4
You mentioned restriction as well in your question although this is possible probably unlikely as well. The probability of restrictions and leaks go up with field connections and go down with factory made sealed units.
Old 07-21-2012, 10:54 PM   #5
Rewards Points: 484
Not to argue, beacause I do agree somewhat that a factory sealed system does tend be better off than a field installed setup but where we live in the land of package units, I have heard of newer units with restrictions and loss of charge issues.
I only do installs and repair the electrical and heating side of these, I never got into the sealed part of them. I guess I'll have to have someone throw some gauges on it and see whats going on, if it's too involved I'll just scrap it.
Question on hooking up the compressor on a Goodman brokenhammer HVAC 2 07-25-2009 11:59 AM
Trane XV90 cfm question lyonkster HVAC 36 04-29-2009 02:28 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Goodman ck36-18 question bub HVAC 3 08-15-2008 05:08 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
