| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Store a Pressure Washer
by Expert Village
In this clip we're going to be talk about breaking down the equipment. It's always important. We're done with our job right here, we need to relocate the pressure washer. It's important, first thing you shut the actual machine off give it a chance to... Read More »
How to Drain an Air Compressor
by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I'll show you how to drain the tank of your air compressor. All compressed air systems generate condensation inside of the tanks, now if you don't drain the tanks on a regular bases rust will... Read More »
How to Drain Radiator Coolant
by Expert Village
In this segment, we're going to cover draining the radiator. Prior to draining the coolant out, first thing we need to do is remove the cap. If the system is under pressure, when you push down on this cap to release it, in order to turn the cap, it's got... Read More »
Plumbing Maintenance in a Hot Tub
by Expert Village
OK, here we're going to talk about how to fill and drain a spa. Some people tend to think they have to be plumbed in or hard plumbed with a current plumbing system in your home. Not the case, you simply grab a garden hose, place the hose into the spa. In... Read More »
How to Run Duct Tests on Homes
by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. If you looked at the duct test that we did earlier, you saw that we had hooked this hose right up here, this... Read More »
