Old 11-29-2007, 03:36 PM   #1
Question
Goodman - pressure switch/condensate trap
Been battling this issue for a while now and hoping for some advice. Furnace is a Goodman ... not sure of model # (not at home right now ... shhhh! don't tell the boss )
Problem is that the tubing from the draft inducer to pressure swith clogs with condensate anywhere from a few hours to a few days running time. Clearing the tubing allows normal start up but is a PITA.
Previous advice has been to check drain lines for blockage. All nice and clean with good flow (cleaned trap and lines). Vent pipe does not appear to have blockage with good airflow to outside vent.
I'm guessing at 2 other possible sources of the problem
1. level of the funace from back to front not allowing proper drainage haven't checked this yet so I don't know if it's off level or not)
2. I've read reference elsewhere to having to re-prime a drain trap after cleaning (assume this just means filling with water to the level of the outflowing tubing)
Any opinions/comments on which of those 2 is more likely or if I'm missing the boat altogether?
jrmac is offline   Reply With Quote
Old 12-02-2007, 09:06 PM   #2
Send a message via Yahoo to mrkool
Well, Goodman told us contractors to strap the tube up so it doesn't act like a drain trap. I've also had to, in different furnace configurations, redrill and reattach the pressure switch tube to a different place and I've used an "airswitch" in place of the pressure switch.
They're small single poll switches whose arm is connected to a small peice of flat metal that when the fan came on, it blew the metal plate, thereby making the switch, worked great for years in old Trane package gas units.
mrkool is offline   Reply With Quote
Old 09-06-2009, 10:38 PM   #3
Customer service/Goodman
Call a qualified Goodcare Dealer simply enter your Zip www.goodmanmfg.com
Customerservice is offline   Reply With Quote
Old 09-06-2009, 11:28 PM   #4
GC/Master Plumber/Mech
Can you post a model number of the furnace?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-07-2009, 05:49 AM   #5
An old Tradesmen
Its a 2 year old post.
Hopefully, the OP got it figured out by now.
goodman pressure switch error 3 blinks mrbac HVAC 4 03-12-2013 12:43 AM
Pressure Fluctuation with well water beertestr Plumbing 5 10-03-2007 10:18 AM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 08:30 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
