Old 04-28-2012, 09:09 AM   #1
Goodman MBR1200AA thermostat question
i am using this handler with a 7k heating element and a regular thermostat (2 wires heat on heat off ) and i was wondering if i could use a different thermostat so i could use the heat or if i wanted too have it just circulate with no heat. any help much appreciated
rikmac1 is offline   Reply With Quote
Old 04-28-2012, 09:43 AM   #2
I'm Your Huckleberry
If you mean by two wires for heat on being first and second stage than many thermostats offer that option.
The thermostat connections are as follows:
W1) First stage heat
W2) Second stage heat
G) Fan (circulation)
Y1) First stage cool
Y2) Second stage cool
R) 24 volts (power)
C) Common, used for powering digital stats
But with one 7 kw strip I'd doubt you have two stages of heat.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-28-2012, 10:09 AM   #3
An old Tradesmen
If you only have 2 wires at the thermostat. You either need to run more wires to the stat, or gt a 2 wire stat that uses an EIM.
Thermostat cooling humidity setting question Mrdippy HVAC 2 07-04-2011 09:47 PM
Newbie question - thermostat functioning and baseboard heaters keith-k HVAC 2 10-26-2010 10:20 AM
Goodman heat not engaging with new thermostat autosay97 HVAC 13 10-17-2010 09:37 AM
Setback thermostat question frontein HVAC 0 09-01-2010 11:39 PM
A/C won't turn off with thermostat temp adjustment ( Goodman system ) rkpatt HVAC 3 07-29-2008 05:58 PM
