Goodman Inducer Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 07:51 AM   #1
gkaro's Avatar
goodman inducer motor
Getting e2 error code on 45K BTU 95 EFF FURNACE. Inducer motor wont start. Voltage across black and white to motor. Bench tested and applied 110v to black and white and red and white....nothing. is this cooked ? Thanks for replies...
gkaro is offline   Reply With Quote
Old 11-21-2010, 10:28 AM   #2
gkaro's Avatar
The error codes may be too specific for this forum. Is anyone knowledgeable enough to know if the three wires to the draft motor are low and high and common/return?
Old 11-21-2010, 05:57 PM   #3
Rewards Points: 508
Mine has black and white with a green ground for my Amana.
See if http://www.fasco.com/pdf/p58.pdf and http://www.fasco.com/pdf/p22.pdf help identify your unit. Dig deeper to find reference # http://www.fasco.com/pdf/p03.pdf under 3.3" diameter motors.
Newer catalog is http://www.fasco.com/prodcat.asp
diyorpay is offline   Reply With Quote
Carrier Model 58MVP inducer motor deanray HVAC 11 11-19-2010 04:33 PM
inducer blower motor Noise snwboarder45 HVAC 5 10-05-2009 10:39 AM
Inducer motor or control circuit? Please help me troubleshoot. averagerob HVAC 1 03-03-2009 01:43 PM
Goodman motor availability NomadTrash HVAC 5 11-08-2008 11:01 AM
Replacing a Condenser Fan Motor (Goodman) guddug HVAC 8 07-03-2008 10:11 PM
