Goodman Ignitor Keeps Burning Out - HVAC - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 09:49 AM   #1
Rewards Points: 518
Goodman ignitor keeps burning out
Hot surface ignitor 20165703S
Goodman furnace is 6.5 years old. We've replaced the ignitor 5 times now. They never last. I tried the nicer carbide replacement as well and it didn't last. Voltage seems within spec, no dust or particle build up, and the surface was not touched during installation. We've kind of come to accept that it's a disposable item for us, but are curious to know why they burn out so often and if it could be a sign of a larger issue. We have the furnace inspected annually and no alarm flags have come up.
n0c7 is offline   Reply With Quote
Old 03-22-2011, 10:44 AM   #2
HVAC / Plumbing
try silicon nitride ignitor
http://www.sdsmarket.com/ProductDeta...FddA2godaCoiAA
kenmac is offline   Reply With Quote
Old 03-22-2011, 06:36 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 116
They should not burn out that often. Probably the relay on the circuit board for the igniter is sticking on. It is supposed to shut it off when the burner flame is sensed. Probably an intermittent problem. Make sure the board is properly secured to the mounting plate and that is properly secured to the fan housing. They can come loose, lose their grounding and burn out.
Old 03-23-2011, 09:38 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Humidity will shorten an ignitors life.
Kyle
Central air burning smell intermittent boku HVAC 7 07-14-2010 09:23 PM
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 02:32 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 03:52 AM
Burning Bush problems/questions sk8z Landscaping & Lawn Care 1 02-14-2008 12:28 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
