Originally Posted by chard
Need to give us some time to get home from our job to answer your questions.
ya well other questions where being answered seemed as if mine was being skipped at the time, sorry about that.
The problem could be a stuck fan relay or a crossed wire between 24v and fan wire. But I would think the latter would keep the A/C on 24/7. Especially if you have an old mechanical t-stat.
So, I am going to say the blower relay is stuck closed.
thanks 4 the reply, the t-stat is a Honeywell T8411R, maybe the thermostat has problems too, it doesn't report the temp correctly sometimes either.
Heres the datasheet i found for the themostat
http://customer.honeywell.com/Techli...0s/69-1037.pdf
Its a central air & heating. Idk if im using the right terminology or not..sorry I'm a kid, but don't let that stop you from helping, i may just be getting info all over the internet to try to see if i can fix it myself. I had fixed our other unit outside for upstairs which needed a dual run motor capacitor because a bug crawled on it and shorted it out. That was an easy fix, i just replaced the capacitor and followed the wiring of how the old one was. This...not so much. I can give you the air handlers model number if needed.
