Goodman HVAC Problem...only Runs On AUX Mode - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 11:40 PM   #1
Post
goodman HVAC problem...only runs on AUX mode
Hello.
I am having an issue with my Goodman HVAC unit (i live in a condo and having a Goodman wasn't by choice!). The unit is a electric heat pump unit. When the thermostat is turned to AUTO and/or ON position, the heat kicks on, however, AUX flashes on the display...this seems to indicate that only the auxillary/emergency heat is working. Also, once the house gets up to temperature, the fan will not stop blowing and it continues to blow around cool air and it will do this continuously until I turn it OFF. Also, the outside unit isn't turning on.
I just had this unit serviced in August for an A/C problem, which was fixed by replacing a transformer on the inside unit and a contactor on the outside unit. The A/C ran perfectly after this. The heat worked properly for approximately 6 weeks and I just started having this problem.
My husband replaced the contactor again, just to see if that was the problem again, but it's still doing the same thing.
I would greatly appreciate any help anyone can give! THANKS!
kerbear413 is offline   Reply With Quote
Old 12-03-2008, 12:51 AM   #2
An old Tradesmen
Rewards Points: 6,140
The service tech may have knocked a wire loose. Or you could have another problem with the outdoor unit.
Sucj as a leak, causing it to be low on charge. And a safety keeping the outdoor unit from running.
Call the same service company back.
Honeywell RTH7000 and Goodman System Problem jvd1812 HVAC 1 11-08-2008 12:51 PM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 03:46 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
creaking wall board or possible hvac problem altoon HVAC 2 01-03-2008 02:40 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
