Old 12-13-2010, 06:17 PM   #1
Goodman Heatpump problem solved!
I have a two year old 2 1/2 ton goodman heatpump that recently stopped heating or cooling. I called a service tech from a respected local contractor. After checking the outside unit for a short time he told me the compressor was bad. Although the compressor was running, there was no pressure. While I was dealing with the warranty issue with an online supplier, I decided to do a little troubleshooting on my own. I just couldn't beleive a two year old compressor was bad. After reading lots of online posts that directed me to many possible faults, I started at the control voltages. All were good. Then I checked the reversing valve. First I disconnected the condenser fan wires, so the fan wouldn't come on during testing. I put the thermostat in heat mode and move the temp up about three degrees. The unit came on and was making a loud modulating noise from the compressor. I used an unorthodox method utilizing a golf club ha! ha! I know what your thinking. I used a old one iron to reach down through the top of the unit and tap on the reversing valve. After a few hard taps the compressor quited down. I reconnected the condensor fan and went iside to find the unit working fine.
I switched from heating to cooling and the valve stuck again. I went through this process a few times with the valve sticking each time. I was persistent and the last time it worked in both heating and cooling. I may have to replace the reversing valve sometime in the near future, but for now its working great. The Moral of the Story: Don't always trust the first service tech. Get another opinion, it can save you a lot of time and money.
Rollie is offline   Reply With Quote
Old 12-13-2010, 06:53 PM   #2
An old Tradesmen
2.5 years old? Sounds about the right age to be one of the ones that has a recall on the RV.
Goodman had a problem with the RV not moving the whole way or at all at times.
Old 12-13-2010, 06:58 PM   #3
Yep sounds about right
Hixheat1 is offline   Reply With Quote
Old 12-14-2010, 09:17 AM   #4
Thanks "beenthere" I didn't think about checking SR's. I found a site that had Goodman SR's and it tuns out my unit is covered by SR-036 which covers replacement of faulty "Dunan" reversing valves. This should save me lots of headaches, warranty shipping and labor charges.
THANKS AGAIN
Old 12-14-2010, 07:52 PM   #5
An old Tradesmen
Your welcome.
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
goodman heatpump tarheelhvac HVAC 8 10-08-2009 10:42 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 10:59 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
