Goodman Heatpump - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 01:38 PM   #1
Goodman Heatpump
I have a goodman split heatpump that is 3 years old the inside fan and out side fan are runing but the compressor want then I raised the thermastat tempature from 73deg to 79deg the system cut off then I set themostat to 69 deg and the compressor started this worked twice and ran well untill the unit met its demand and compressor switched off and now that trick wont work. what could it be ? a capacitor?
drdave193@aol.c is offline   Reply With Quote
Old 07-07-2011, 05:49 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
possibly a capacitor or a failing compressor or low on charge and internal overload is tripping.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
drdave193@aol.c (07-07-2011)
Old 07-07-2011, 09:18 PM   #3
thanks I installed a new capacitor and it fixed the problem
Goodman heatpump subcooling too high Rollie HVAC 4 01-06-2011 11:27 AM
Goodman Heatpump problem solved! Rollie HVAC 4 12-14-2010 06:52 PM
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 02:32 PM
goodman heatpump tarheelhvac HVAC 8 10-08-2009 09:42 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
