Goodman Heat Pumps - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 01:52 AM   #1
Goodman heat pumps
I just installed a 2.5 ton goodman heat pump in a home that replaced a carrier , the air handler is carrier but was not replaced , we also installed a new honeywell 3550 thermostat which was programed per factory specs, my problem is the heat pump will run in heat mode but will not cool , I have been doing this for years but I must say that after a few days working on this problem I'm stumped , so now I'm reaching out for any suggestions I may be able to find , the only thing I have found so far is the my helper installed the filter dryer in the wrong direction but I have saw them work that way as well ,(I'm going to change that today) so anything anyone could throw out there that I may not have tried is more than welcome!!! HELP please.......thanks
jlz88 is offline   Reply With Quote
Old 07-08-2013, 03:36 AM   #2
Experienced HVAC Tech
HVAC1000's Avatar
How can the filter dryer be the wrong direction. Aren't u supposed to use a two directional filter dryer on a heat pump, being that it is, well, a heat pump and the refrigerant changes directions.
HVAC1000 is offline   Reply With Quote
Old 07-08-2013, 06:59 AM   #3
dryer
thats true but he did not use a bi-flow dryer but a single flow off my truck that was there for an A/C only system that I am suppose to install today. thanks
Old 07-08-2013, 07:53 PM   #4
sktn77a's Avatar
Rewards Points: 388
Make sure the reversing valve connector from the heat pump to the thermostat is set to "O", not "B". The Goodman should be the same as the old Carrier (only Rheem/Ruud use the "B" connection, to the best of my knowledge).
sktn77a is offline   Reply With Quote
The Following User Says Thank You to sktn77a For This Useful Post:
jlz88 (07-08-2013)
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 04:34 AM
Fan motor for a Goodman CPKE24-18 heat pump scole HVAC 2 03-25-2011 06:25 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Is there an effective assist for heat pumps? jackofmany HVAC 1 12-03-2010 11:12 AM
Wow! Heat Pumps Rock! zootjeff HVAC 3 11-23-2010 08:24 PM
