Goodman Heat Pump - W2 Wire To Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2013, 02:24 PM   #1
Goodman heat pump - W2 wire to thermostat
I'm a bit unclear as to the purpose of the W2 connection at the heat pump, with respect to my Vision Pro TH8320U1008 thermostat. I have a GSZ130181 heat pump and GMH950453BX furnace (2 stage furnace that uses single stage thermostat hookup).
There's a terminal on the thermostat marked AUX (for heat pump) and W2 (for conventional heat) . I've got that hooked up to the heat terminal on my furnace for auxiliary/emergency heat, and field jumpered to terminal E.
There is a terminal L on the thermostat described as "heat pump reset / equipment monitor". (Powered continuously when set to Emergency Heat, system monitor when set to Heat, Cool, or Off)
1.
Should the W2 wire on my heat pump be hooked up to L, AUX, or E on my thermostat?
2.
Am I correct in jumpering E to AUX, as Honeywell says to do "if there is no emergency heat relay"?
3. Is it correct to use E and AUX for the heat call signal to the furnace?
taxmantoo is offline   Reply With Quote
Old 07-18-2013, 03:33 PM   #2
Rewards Points: 6,652
W2 lands on the thermostat as it states, if you are using a heat pump. The manual that comes with the thermostat, furnace, heat pump has te wiring diagrams in them.
They are your best friend, and are better than a Internet forum, that none of us are physically there.
Really it is pretty straightforward, just make sure no power is on on the furnace or heat pump while you are connecting the thermostat, otherwise you will fry stuff.
Old 07-18-2013, 04:26 PM   #3
Manuals:
Heat Pump (there's more detail in the wiring chart on the access panel)
Furnace
Thermostat
Alpine's web site has a handy little diagram for controlling dual fuel with a Vision Pro, but they don't use the W2 on the heat pump or jump AUX and E on the thermostat.
The thermostat doesn't have a W2 in the 'heat pump' column of terminal labels, but the thermostat's heat pump AUX is the same terminal as the conventional furnace W2.
According to the thermostat manual, I'm supposed to hook the furnace's white wire to the thermostat's AUX, and apparently jumper it to E.
Should I just go by the Alpine diagram and ignore W2 and Honeywell's E-AUX jumper comment?
My main problem is the heat pump documentation just says the white wire is W2 without explaining what W2 does. If I don't need it, what's it there for?
Old 07-18-2013, 04:28 PM   #4
An old Tradesmen
Rewards Points: 7,278
The W2 from the heat pump can land on either the W terminal of the furnace, or the W2 of the stat.
Yes, jumper aux and E.
Yes, aux and E are what runs the furnace for heat, when it is needed.
Did you install the outdoor temp sensor.
The Following User Says Thank You to beenthere For This Useful Post:
taxmantoo (07-18-2013)
Old 07-18-2013, 04:38 PM   #5
So HP(W2)=T-Stat(AUX+E)=Furnace(W)?
Yes, I've got the outdoor sensor on S1 and S2 of the 8320. Found out that when the sun hits the west glass of my sunroom late in the evening the outdoor temp goes into the mid-90s when it's only 88 outside, so just west of the sun room in the shade on the north of the house isn't the greatest place for it. Thinking of putting the temp sensor in the shade under the heat pump, or I can leave it on the north side of the house and try moving it 15' further from the sun room.
Old 07-18-2013, 04:39 PM   #6
An old Tradesmen
Thats it.
Old 07-18-2013, 05:42 PM   #7
Yes, always place the sensor where there is shade all day if you can. Placing it where Heat gain or direct sun will skew the sensor readings, will do nothing for you. Same goes where during Winter if you are in an area that gets below zero temps with high winds, you want it where it will not wind blowing past it, that can also skew the results.
Old 07-18-2013, 05:45 PM   #8
An old Tradesmen
Wind will have no effect on it.
Old 07-18-2013, 05:48 PM   #9
It's in a zero sun area on the north side of a house, but apparently there's a serious radiant heat factor when the sun gets low enough in the evening to hit a glass room addition that's 3' away from it.
I can relocate it so it's still on the north side of the house but 18' away from the sun room, or I can put it in the shade under the heat pump, where it might pick up radiant heat from the ground. Or maybe leave it where it is and put a reflective barrier between it and the sun room?
Old 07-18-2013, 05:51 PM   #10
An old Tradesmen
Any one of those options should work.
Old 07-18-2013, 06:30 PM   #11
Actually Cold Wind during Winter does affect Thermometers if the wind speed is high enough.
http://physics.stackexchange.com/que...ne-shielded-fr
Old 07-18-2013, 06:48 PM   #12
Greg, your link seems to indicate what beenthere said.
"Why, given two temperature sensors or thermometers in the same environment, do both report the same temperature if one is exposed to wind when the other is shielded from it?"
"Its really pretty simple, the thermometer measures temperature, wind chill measures heat loss for a body warmer than the air. Wind makes more unheated air available to conduct heat away from a hot body, but with a body at air temperature no heat is being condicted away from the thermometer."
"The thermometer in wind will (at equilibrium) show a lower temperature than one in still air, if and only if it is a wet-bulb thermometer."
The only conflicting answer was the one that said if you have radiant heat sources the still air sensor will be warmer and the windy sensor will be closer to air temperature. Therefore wind isn't something to be avoided, it's something to be sought after, but only if there's a major radiant source (like my sun room) or you're looking for more precision than is required to set the 5F range in which the thermostat switches from heat pump to furnace and back.
Old 07-18-2013, 08:26 PM   #13
An old Tradesmen
Wind chill only effects objects that contain and or generate heat. So a thermometer isn't effected by wind/wind speed. It can only show display the actual air temp, within its accuracy range. The same as it would if no wind was blowing.
Help rewiring control system for multistage heat pump ink HVAC 12 12-10-2012 09:23 PM
New Trane Heat Pump Thermostat cory_booth HVAC 0 08-30-2012 08:44 AM
Breakers, wire size and new heat pump ACR_SCOUT Electrical 21 01-29-2012 02:25 PM
Heat Pump Thermostat wiring SHBicycle HVAC 23 03-15-2011 02:28 PM
Multi stage heat pump thermostat marriedmanw HVAC 2 02-28-2010 04:12 PM
