Goodman Heat Pump Troubles - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 02:25 PM   #1
Goodman Heat pump troubles
I have a 2008 4T 14 seer Goodman Heat pump. This winter the fan will come on while something else is making a loud humming noise. This noise cycles on and off like something is trying to start. The cycling has longer intervals until whatever it is starts. It could start first time but it might take up to 10 cycles. Any ideas what I should check?
joeyn is offline   Reply With Quote
Old 11-27-2012, 04:46 PM   #2
Check for a week capacitor
Old 11-27-2012, 05:00 PM   #3
An old Tradesmen
Rewards Points: 6,590
Yep, good chance its your compressor you hear trying to start. You want to take care of this ASAP, so your compressor doesn't become damaged.
Electric baseboard VS Heat pump Mattme123 HVAC 20 09-21-2012 09:41 PM
Bad Goodman Heat Pump model DSZC18 swillis HVAC 8 08-04-2012 08:33 PM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
