Old 06-22-2011, 03:20 PM   #1
Goodman heat pump outdoor unit problem
The electrical solenoid on the "Contactor" buss will not function.
Nor will the "diverter"(?) valve to switch between heat and cool.
Does this sound like a bad circuit board?
It's getting the required 24 volts, but doesn't seem to be controlling anything.
Thanks.
Shadowman756 is offline   Reply With Quote
Old 06-22-2011, 05:42 PM   #2
Hvac Pro
Post the complete model and serial #. Where and how are you checking for 24 volts. Be specific. Cannot go to ground on outdoor units. Need to check to the common wire back to the indoor unit. I don't do many heat pumps but we have other Pros here that do.
Goodman Heat Pump 01fordeb HVAC 13 03-16-2011 05:17 PM
Trane XR11 heat pump problem with compressor not always starting right away.. mikebdub HVAC 11 01-29-2011 06:38 AM
Trane XL1200 Heat Pump Condenser Fan Problem peglegpirate HVAC 3 10-20-2009 10:43 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Goodman Heat Pump defrost noise RCApp HVAC 1 12-17-2008 07:54 AM
