Goodman Heat Pump- No Air From Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 09:09 PM   #1
Goodman Heat Pump- No air from vents
I have a Goodman Heat Pump Model PHK042-1 and have never had any problems before (and it waits till this close Christmas). Several days ago, the unit came on and air came through the vents for about 2 minutes and stopped. No smell of smoke noted. I turned unit off and went back later and tried it, still no air. Went outside, large fan was running. Took panel off of indoor blower assembly-- found switch throwed- I reset this and tried again. still nothing. I replaced the capacitor. Still nothing. I now see that the wires going to the transformer look like they are slightly melted. Could the transformer be the source of my problem?? I can't afford to keep spending money to try different things and also can't afford a service call right now. Please if anyone can help with this, I would greatly appreciate it.
medic32 is offline   Reply With Quote
Old 11-28-2012, 09:25 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Burnt wires are never good. Usually a short would take out the transformer but yes, you need a transformer for low voltage.
You have an electrical meter?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-28-2012, 09:34 PM   #3
I do have a multi meter but not completely sure if I know how to use it.
Old 11-28-2012, 09:47 PM   #4
You'd need to able to test ohms/continuity and voltage.
Thanks.
Old 11-28-2012, 09:55 PM   #5
As a dumb female, I own the tool just don't totally understand how to use it. I do appreciate your trying to help me though. I can replace parts but don't really know hoe to test them.
Bad Goodman Heat Pump model DSZC18 swillis HVAC 8 08-04-2012 08:33 PM
Replace Florida Heat Pump AC with reg AC? Rheem or Goodman? FrankL HVAC 5 07-22-2012 11:42 PM
Goodman Heat Pump 4scoops HVAC 3 06-06-2011 10:45 AM
Goodman Heat Pump 01fordeb HVAC 13 03-16-2011 05:17 PM
Goodman Heat Pump - Blower Motor FireFighter254 HVAC 9 03-05-2010 07:18 AM
