Goodman Heat Pump Making Clicking Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2015, 04:17 PM   #1
Rewards Points: 127
Hello everyone,
Today I noticed the indoor unit of my Goodman heat pump makes a clicking noise every 3-4 minutes. The unit is in heat mode and is not running when I hear the noise. The unit was installed in 2009 and this is the first time I've noticed this clicking noise. It sounds like something in the unit is clicking on, then clicks off after a few seconds. This happens every 3-4 minutes. Is there anything I can try or look at before I call a tech? It does not seem to be affecting the performance of the unit, as it will kick on when the temp drops. The noise is very noticeable; you can hear it through the vents.
Thanks for the advice.
wkumtrider is offline   Reply With Quote
Old 12-05-2015, 07:14 PM   #2
Rewards Points: 3,256
Do you have electric auxiliary heater strips? Perhaps the heat is stuck on and cycling with the overheat limit switches. If you don't have an amp clamp take a look at you electric meter and see if it's speeding up and slowing down.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
Bob Sanders (12-05-2015)
Old 12-05-2015, 09:32 PM   #3
Rewards Points: 3,274
What zappa says.
You'll notice a higher than normal electric bill too.
Bob Sanders is offline   Reply With Quote
Old 12-06-2015, 11:42 AM   #4
Rewards Points: 127
Thanks guys. It does have auxiliary heat strips. I'll take a look at the electric meter to see if it speeds up when the clicking starts. It also makes a humming sound between the two clicks.
Old 12-06-2015, 11:53 AM   #5
Rewards Points: 127
Just confirmed the electric meter does speed up quite a bit when I hear the clicking noise, and then slows back to normal when it clicks the second time. Is there anyway to disable this until I can get a tech out to look at it?
Old 12-06-2015, 01:35 PM   #6
There are many easy ways to disable it but you need to be good with reading schematics and electrical work.
As an alternative you could flip the breaker off for the air handler and only turn it back on when you need heat.
Old 12-06-2015, 02:02 PM   #7
Rewards Points: 127
Thanks zappa. I turned the unit off at the breaker. I am not comfortable messing with it (although I can read schematics.) I'll get the a tech out tomorrow hopefully. Do you think it is a faulty switch that is causing the issue?
Old 12-06-2015, 02:40 PM   #8
Something is probably stuck closed, like a contactor or sequencer. Both could also be called switches.
wkumtrider (12-07-2015)
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
replacing a smartway VT2005 thermostat for a goodman heat pump barrtrack2 General DIY Discussions 0 06-01-2015 03:29 PM
Goodman Heat Pump Jumpered Reversing Valve tom1336 HVAC 14 07-21-2012 02:11 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Heat Pump Noise in Heat keepitfrozen HVAC 2 12-26-2009 02:47 PM
