Goodman Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 08:28 AM   #1
Goodman Heat Pump
Air Handler will not shut off. Turning off at thermostat has no effect.
Have to turn off by breaker
Bobby48 is offline   Reply With Quote
Old 12-17-2012, 09:59 AM   #2
Willing to listen
Rewards Points: 215
Possible stuck relay in the thermostat or on the Air Handler control board. Does it stay on all the time if thermostat is set to off (not heal or cool) but fan on is set to on?
You should be able to test with a multimeter to see if the thermostat is constantly outputing 24V on "G" to eliminate stat as a possibility.
Done That is offline   Reply With Quote
Electric baseboard VS Heat pump Mattme123 HVAC 20 09-21-2012 09:41 PM
Bad Goodman Heat Pump model DSZC18 swillis HVAC 8 08-04-2012 08:33 PM
Heat Pump Crisis, Help! Doc Holliday HVAC 14 12-02-2011 10:22 PM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
